 Gearbox oil
Auser
Posted - 04 Feb 2014 :  23:02:35  Show Profile  Reply with Quote
Ciao ragazzi, dovendo cambiare l'olio del cambio alla mi9a mr2 mk3, non ho indicazioni precise (dai vari siti, forum ecc.) sulla quantità...
Chi dice 1.8 litri, chi dice 2.1 litri (come il mio libretto uso e manutenzione) chi dice 1.9 litri, ecc.
Nessuno sa darmi indicazioni precise?
Forse ci sono 4 diverse quantità per 4 diverse situazioni?
- 5 marge smt
- 5 marce non smt
- 6 marce smt
- 6 marce non smt
La mia è 6 marce non smt.
Chi ne sa qualcosa?
Grazie ;)
Auser
Posted - 07 Feb 2014 :  14:24:03  Show Profile  Reply with Quote
Posted - 08 Feb 2014 :  01:49:07  Show Profile  Visit SMOGBIKER's Homepage  Reply with Quote
ti bastano 2 lt. riempi con il siringone...e quando comincia a fuoriuscire dal tappo di rabbocco....chiudi il tappo.
Auser
Posted - 25 Feb 2014 :  20:54:21  Show Profile  Reply with Quote
Max...
...pratico e diretto....come sempre ;)
Birnbaum
Angola
Posted - 11 Mar 2014 :  05:19:44  Show Profile  Visit Birnbaum's Homepage  Send Birnbaum an AOL message  Send Birnbaum an ICQ Message  Send Birnbaum a Yahoo! Message  Reply with Quote
Carmakers say that modern gearboxes don¡¯t need oil changes at all and will last the life of the car. There¡¯s not much you can do yourself at home, but if you want your gearbox to really last as long as possible I¡¯d recommend changing the oil every 50,000 miles. Take your car to your garage or fast fit centre and ask them to drain the oil and replace it with the appropriate Castrol gear oil. The whole job should cost less than ¡ê50 (check) and will prolong the life of the gearbox and make it feel smoother. While you¡¯re at it ask them to change the axle oil too if you¡¯ve got a rear wheel drive or four wheel drive vehicle.
www.carobd2shop.com
