 grounding kit su ebay
semlor Posted - 09 Jan 2009 : 12:29:48
Non so quanto possa servire realmente ma appare ben fatto.
Acquistando dal sito sembra non ci siano spese di spedizione
http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=360105100386
Mr2EnJoYeR Posted - 23 Jul 2011 : 17:21:53
hahahahahh ed io ke stavo pensando al trapianto...ke fesso ke sono stato
ciavatta Posted - 12 Jan 2009 : 23:51:48
saranno almeno 30Cv in più di pUtenSa e, minimo-minimo, 50W in più all'amplificatore.
semlor Posted - 12 Jan 2009 : 23:08:31
dice l'inserzione
How does a grounding kit work?
Installing a grounding kit is a safe and reliable way of creating a low resistance ground path. The kit provides direct ground paths from battery negative to body, chassis, and specific engine components to give a noticeable improvement in electrical circulation.
Reduced electrical “noise” can improve ECU signals and throttle response resulting in better performance and reduction in flat spots, and you can see many more benefits associated with improved grounding such as increased bhp & torque, stabilised idle, brighter headlamps, quicker starting, reduced audio noise, reduced heater matrix/radiator core corrosion.
berimbao Posted - 12 Jan 2009 : 13:51:09
scusate la domanda ... ma a che serve ? non è abbastanza il collegamento tradizzionale ?
